Vicious |
Newbie ![]() Group: Members Posts: 35 Joined: 31-October 22 From: South Dakota, USA Member No.: 26,958 Region Association: Upper MidWest ![]() |
The engine cooling fan on the motor that came with my car has several broken fins/blades. Looking for a replacement i can only seem to find used part? Does no one produce oem style or aftermarket replacements for this? Is used my only option?
Sorry if this has been covered. Did not find anything in the search. |
Artfrombama |
Member ![]() ![]() Group: Members Posts: 266 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Whatever fan you source, would be wise to check #1TDC with a dial indicator to verify the notches on the fan/shroud are correct.My $.02
Vicious |
Whatever fan you source, would be wise to check #1TDC with a dial indicator to verify the notches on the fan/shroud are correct.My $.02 Looks like I'm making a deal for a very nicely restored family from cholland that has no indicator marks on it so will need to do that either way. That will require some more research. By the time this cars on the road I'm sure i will have annoyed at least half the forum with my constant questions |
Lo-Fi Version | Time is now: 3rd April 2025 - 12:45 PM |
