gnomefabtech |
Member ![]() ![]() Group: Members Posts: 146 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None ![]() |
Hello all-
So, I'm finally able to turn my attention to the suspension on my car now that it's running. The car was hacked for a v8 when I got it and I have instead done my Hayabusa engine swap. I'll have to make a separate thread on the adaptor setup, but it's mounted north south and uses the original 901 trans. Dynos at about 300whp with turbo. 2k lbs overall weight. Narrow body. The PO added some crazy stiff rear springs on coilover sleeves and they need to go. Also the front is way too stiff. It's all 911 front suspension and brake parts. Questions: I'm thinking about 140# springs in the back, but how long a spring should I use. 14"? 12"? Helper springs? In the front I think it might have like 21mm bars, and that's way too stiff. Are normal 19mm 911 bars soft enough for a street driven 914? Or are there thinner 911 compatible bars? Thanks! |
flxzcat |
Newbie ![]() Group: Members Posts: 35 Joined: 13-June 11 From: lake forest socal Member No.: 13,188 Region Association: None ![]() |
My new to me 914-4 is 1825lbs weighed last week on Longacre scales and a 44%-56% balance (I like adding lightness)
Somehow, I got talked into 21mm hollow bars up front and 250lb coils in back. The car is way too stiff on the street and I consider myself a hard-core racer canyon carver type. I will soon be changing to 19mm front and 180lb rear. |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,069 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
My new to me 914-4 is 1825lbs weighed last week on Longacre scales and a 44%-56% balance (I like adding lightness) Somehow, I got talked into 21mm hollow bars up front and 250lb coils in back. The car is way too stiff on the street and I consider myself a hard-core racer canyon carver type. I will soon be changing to 19mm front and 180lb rear. Still to much. |
Lo-Fi Version | Time is now: 3rd April 2025 - 09:38 AM |
