> FI Plenum Design, MS'ing my 2270
Tom Perso
post Feb 1 2005, 07:41 AM
Crazy from the Cold...
Hey Guys,
I am designing a MS system for my 2270 (163.86b cam, 48x38 valves, future Triad header). I am looking at running stock intake runners and possibly making a new plenum to run my Ford TB (probably from a 4.0L Exploder/Ranger).
Are there any "design guidelines" that should be followed when making a new plenum, such as a certian volume required for engine displacement?
Looking at space requirements, I see running the TB on top of the plenum is the only way to go. That, of course - begs the question... Is the stock 914 2.0L plenum a good starting point to modify to allow for the Ford TB?
Here are some pics for reference... I had a Bus 2.0L intake system to borrow, so I am basing my measurements and ideas off of that.
http://www.qtm.net/~persot/MS/
Any ideas, suggestions, etc, are appreciated!
Thanks,
Tom
Brett W
post Feb 4 2005, 08:16 AM
I never claimed to be settling any argument by what I wrote. I was asking how you figured a 300%+ increase in plenum volume for a 13% increase in displacement, given the stock intake runners. I'm still not sure. But I can respect what you know. Just don't read more into what I wrote than I intended. Like most here, I am trying to learn.
I am not working on ratios from the stock parts. I feel they are to restrictive. Based on the calculations I have done on some Honda engines and Suzuki engines I feel that the plenum on the 914 is too small for good performance in the range where a good high performance engine will make its best power. Although a plenum system will always offer less throttle response than an IR type system, it can make more overall power. Most guys with a 914 will want throttle response over maximum power.
My suggestion was simply to look at something that works and start from there. You can look at Hondas, I am looking at Porsches (including type 4s.) Maybe Porsches don't work the same way your Hondas do, but I think I can assume Porsche's engineers know a thing or two about engine design. Did they build it "right?" I think you answered that yourself: "all engines are a compromise..." Not just factory stock engines. Yes, even Honda engines. So why dis the Porsche engineers for the compromises they chose? Don't agree with them? Fine. That hardly makes them wrong.
I look at Honda because I feel that, as far a production NA engines, they are some of the most highly developed. I am not "dissing" Porsche engineers, I am making a statement about what I feel is some drawbacks to how Porsche does things. Please stop thinking of the T4 as a Porsche motor. Porsche would hardly have anything to do with this engine if it weren't for the original success of the early 70s cars.
All this being said I am stating my opinions based on my experiences and research. When VW decided to make the T4 an oversquare engine they had to do something to create torque. That is the part reason behind the 54+ inch exhaust primaries and common plenum design with very long runners and a small throttle body. Increase torque. When you modify the factory engine beyond the stock characteristics you move the powerband up in the rpm range. Thus creating the need for more airflow.
Tom Perso   FI Plenum Design   Feb 1 2005, 07:41 AM
DNHunt   Tom I haven't really run my car enough to tel...   Feb 1 2005, 08:05 AM
maf914   Tom, Didn't Shad Laws build a plenum for a la...   Feb 1 2005, 08:19 AM
Jake Raby   With the cam that I set Dave up with, his plenum h...   Feb 1 2005, 08:21 AM
Tom Perso   Lots of good replies - thanks! I have seen Sh...   Feb 1 2005, 08:35 AM
DNHunt   Tom Don't give up on this. I believe there i...   Feb 1 2005, 08:46 AM
Tom Perso   I heard that running a new-unused fuel filter inli...   Feb 1 2005, 08:52 AM
914efi   SDS has an option for locking in a fuel value at a...   Feb 1 2005, 09:20 AM
Jake Raby   There may be ways to help the situation at idle, b...   Feb 1 2005, 09:21 AM
Tom Perso   ...   Feb 1 2005, 09:30 AM
Jake Raby   AThe idle is also inconsistent with an early openi...   Feb 1 2005, 09:53 AM
Tom Perso   Well, I've got the Mallory, so I can dink with...   Feb 1 2005, 10:11 AM
Brett W   Tom I will have to agree with Jake on this one. T...   Feb 1 2005, 12:00 PM
Reiche     Feb 1 2005, 04:13 PM
DNHunt   I think a more accurate statement is I got it to r...   Feb 1 2005, 04:56 PM
Brett W     Feb 1 2005, 06:56 PM
SirAndy   ...   Feb 1 2005, 07:24 PM
jwalters   http://www.914world.com/bbs2/html/e...   Feb 1 2005, 07:36 PM
Reiche     Feb 2 2005, 08:42 PM
SirAndy     Feb 3 2005, 12:17 PM
Tom Perso   Bringing this post back to life.... Any thoughts ...   Feb 3 2005, 04:29 PM
Bleyseng   For starters, lay a 1 gallon paint thinner can on ...   Feb 3 2005, 08:07 PM
TimT   Try to make a plenum along the line of this one. ...   Feb 3 2005, 08:22 PM
TimT   nuther   Feb 3 2005, 08:23 PM
Brett W   Tim, if you would be so kind as to take a tape mea...   Feb 3 2005, 11:10 PM
Bleyseng   Brett, What are the valve sizes of that motor?   Feb 3 2005, 11:28 PM
Brett W
  Feb 3 2005, 11:41 PM
Brett W   My SOHC 1.6 has 29mm intakes and 25mm exhaust. No...   Feb 3 2005, 11:44 PM
Reiche     Feb 4 2005, 02:19 AM
Tom Perso   <...   Feb 4 2005, 06:01 AM
Brett W
  Feb 4 2005, 08:16 AM Mark Henry   Not VW/Porsche but some tips on building a plenum ...   Feb 4 2005, 07:59 PM
Bleyseng   I just think that a inline 4 plenum design doesnt ...   Feb 5 2005, 12:15 AM
Reiche     Feb 5 2005, 12:41 AM
airsix     Feb 5 2005, 01:20 AM
Brett W   Turbo plenums are different. If you are going to ...   Feb 5 2005, 01:56 AM
cnavarro   Tom, I still have the original plenum that we fabr...   Feb 5 2005, 07:37 AM
Mark Henry   I'd like to see that too Charles....I'm st...   Feb 5 2005, 09:56 AM
TimT
  Feb 5 2005, 02:08 PM
Mark Henry   Holy fuch! http://www.914world....   Feb 5 2005, 08:38 PM
Brett W   Thanks Tim, I knew it was big but not that big.   Feb 5 2005, 09:21 PM
- Lo-Fi Version Time is now: 26th April 2025 - 02:50 AM
