> Trialing Arm Alignment Check/Service
friethmiller
post Apr 8 2025, 11:01 AM
I would like to check the alignment of my trailer arms before I recondition them for the LE. I know there's a Lamont guy in CA that had a jig for 914 trailing arms, which he used to reinforcement the arms. My main concern is the driver side that got hit in an accident long ago. Does anyone know of anyone that can do this check? Tangerine Racing no longer does it and Elephant and PMB provide a reinforcement service. Is there any way I can DIY?
mlindner
post Apr 8 2025, 02:57 PM
Why don't you check your alignment first....if good or within adjustment then just add the reinforcement clam shells. Best, Mark
friethmiller   Trialing Arm Alignment Check/Service   Apr 8 2025, 11:01 AM
technicalninja   :popcorn: I'm interested in what other membe...   Apr 8 2025, 12:01 PM
friethmiller   I DO have 100% absolutely straight arms completel...   Apr 8 2025, 12:52 PM
mepstein   I bet you could do a check on a flat surface with ...   Apr 8 2025, 01:58 PM
mlindner   Why don't you check your alignment first....if...   Apr 8 2025, 02:57 PM
friethmiller   Why don't you check your alignment first....i...   Apr 8 2025, 03:16 PM
Montreal914   Too bad CFR doesn’t do these anymore. I liked h...   Apr 8 2025, 09:10 PM
mepstein   Too bad CFR doesn’t do these anymore. I liked ...   Apr 8 2025, 09:23 PM
Dave_Darling   There is a measurement in the Haynes manual (photo...   Apr 9 2025, 06:01 AM
friethmiller   There is a measurement in the Haynes manual (phot...   Apr 9 2025, 07:13 AM
seanpaulmc   There is a measurement in the Haynes manual (phot...   Apr 9 2025, 08:04 AM
friethmiller   ... I'm sure the DAPO, drove it "moder...   Apr 9 2025, 08:28 AM
Dave_Darling   Shoot! That was the photo I was rememberi...   Apr 11 2025, 02:28 PM
mlindner   This sounds like a job for Ben McFarland. He knows...   Apr 9 2025, 06:03 AM
bdstone914   friethmiller ' date='Apr 8 2025, 10:01 AM...   Apr 9 2025, 06:59 AM
friethmiller   I would get a replacement from a car that has not...   Apr 9 2025, 07:15 AM
technicalninja   That is the INCORRECT way to align the outer trail...   Apr 9 2025, 08:26 AM
Maltese Falcon   You can always MiG weld a basic steel structure (j...   Apr 9 2025, 10:03 AM
friethmiller   You can always MiG weld a basic steel structure (...   Apr 10 2025, 01:01 PM
technicalninja   You should bribe or blackmail the Falcon into givi...   Apr 10 2025, 03:06 PM
Maltese Falcon   Blue dot if you look close= small .250" ga. (...   Apr 11 2025, 04:48 PM
- Lo-Fi Version Time is now: 19th April 2025 - 08:32 AM
