East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,840 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
So here’s my next project now that the Safari 914 is done. I don’t anticipate getting into it until fall/winter, but I now have the base for the project. It’s a 1941 Cadillac series 61 that I plan to put on a modern Escalade platform.
If there’s interest I’ll update this as a project thread. I realize this is far from the intended scope of this forum, and if there’s no interest I’ll not fudge up the forum with this non-914 project. But if there’s interest, I’ll post progress once I dig in. ![]() ![]() |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,932 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
You may want to "Z" cut those rails rather than chopping a vertical cut
This will make a way stronger butt joint. Then a plug welded plate |
East coaster |
You may want to "Z" cut those rails rather than chopping a vertical cut This will make a way stronger butt joint. Then a plug welded plate I’m still debating that in my mind…..research is showing straight cut for a fully boxed frame and “Z” cut or step cut for C-channel (unboxed frame). This is a boxed frame, but I still may Z cut it. Either way, it will be plated on both sides after welding. |
Lo-Fi Version | Time is now: 29th April 2025 - 07:18 AM |
