s13u74cr4 |
Newbie ![]() Group: Members Posts: 24 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest ![]() |
Wrapping up my new fuel lines under the shelf. No matter how many times I have drained/siphoned there has been gas on my face again and again. While it is this "dry" I am thinking I should pull the fuel tank out and check out how it's looking down there as realistically it will never be this "dry" again.
Any reason not to have a peek? Anything I should inspect specifically? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,201 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
For future reference, to empty the tank without the mess, i always just manually run the fuel pump until it's empty.
Undo the fuel line after the pump and route it into a large canister. Apply 12V directly to the fuel pump (don't leave the ignition key ON, it can kill some aftermarket electronics). Just make sure that your canister of choice is large enough. (IMG:style_emoticons/default/shades.gif) |
s13u74cr4 |
For future reference, to empty the tank without the mess, i always just manually run the fuel pump until it's empty. Undo the fuel line after the pump and route it into a large canister. Apply 12V directly to the fuel pump (don't leave the ignition key ON, it can kill some aftermarket electronics). Just make sure that your canister of choice is large enough. :shades2: So simple, so genius. Wish I had thought of that. PO put SS lines in the tunnel. Peering into the area it shore looks like they are kinked. |
Lo-Fi Version | Time is now: 29th April 2025 - 07:26 AM |
