> Any reason I should NOT remove the tank?
s13u74cr4
post Apr 23 2025, 03:55 PM
Wrapping up my new fuel lines under the shelf. No matter how many times I have drained/siphoned there has been gas on my face again and again. While it is this "dry" I am thinking I should pull the fuel tank out and check out how it's looking down there as realistically it will never be this "dry" again.
Any reason not to have a peek? Anything I should inspect specifically?
post Apr 23 2025, 04:21 PM
Resident German
For future reference, to empty the tank without the mess, i always just manually run the fuel pump until it's empty.
Undo the fuel line after the pump and route it into a large canister.
Apply 12V directly to the fuel pump (don't leave the ignition key ON, it can kill some aftermarket electronics).
Just make sure that your canister of choice is large enough.
s13u74cr4
post Apr 25 2025, 09:15 AM
QUOTE(SirAndy @ Apr 23 2025, 03:21 PM) *
:shades2:
So simple, so genius. Wish I had thought of that.
PO put SS lines in the tunnel. Peering into the area it shore looks like they are kinked.
ClayPerrine
post Apr 25 2025, 10:00 AM
QUOTE(s13u74cr4 @ Apr 25 2025, 10:15 AM) *
I have an airtex e8445 pump with long suction and discharge hoses on it. I have long electrical wires attached to it with big battery alligator clips on the ends. When I have to pull a tank, I put the suction end in the tank, and put the other end in the fuel filler of my pickup. Hook up the wires to the battery and suck the tank dry.
I also carry it in the trailer box when traveling long distances. I make sure the 914 is full of gas so I can transfer it to the tow vehicle if I get caught out somewhere where there are no open gas stations, or no stations at all. That way I have a 16 gallon emergency reserve of gas to get us out of the no gas zone.
And if the fuel pump fails on the 914, I can use it as a replacement. (IMG:style_emoticons/default/piratenanner.gif)
- Lo-Fi Version Time is now: 29th April 2025 - 07:24 AM
