> Miss fire on cly 4, 73 d-jet
rfinegan
post Sep 24 2024, 07:51 AM
I have been narrowing down the Root Cause on a misfire 73 2.0 D jet. Cold it hits on all 4 but as it warms up I have a miss. Compression a little low but may be washed down rings. 10% leak down/ seem to seal up ok.
When I disconnect the injector no change. Plug back in no change
Noid light check for pulse PASS
Spark getting to the plug PASS. Change plug anyhow as it was new and unknown state
Gut tells me I have an injector acting odd
Today I ran the same basic test: I had a good idle but fast, 1300-1500. Figured I has hitting on 4 now...I pulled the wire off the injector and the speed went UP.. plugged back in and the speed went back down. WTF
NEXT STEP:
1) add fuel gage and confirm pressure ; adjust regulator as needed ( fuel Line kink has been fixed (was lean) pressure base line unknown
2) swap injectors 3/4 see if problem follows to Cly 3. (best)
Or put a different injector in Cyl 4 and test for new behavior (lazy)
Other: I borrowed my 123 Distribute and installed in the 73 2.0 to base line an ignition problem (jumping Tach) Root Cause was a Coil installed backwards.
Smoke machine test shows no Vacuum leaks. Ever so slight leak at throttle shaft, but feels great
Curious as to see if others feel that injector is off in the weeds? Sticking and now leaking?
Ron914
post Apr 25 2025, 10:30 AM
I used Mr Injector to test and clean my original Bosch green injectors to like new . He did a great job and was cheaper than replacing with the FJ67 injectors. $88.00 plus $9.50 shipping
- Lo-Fi Version Time is now: 14th December 2025 - 05:25 AM
