> Pertronix II trigger and 0.6 ohm coil with points backup
SVG223
post Apr 24 2025, 04:23 PM
In case of a Pertronix 2 failure, I want to keep points or a cheaper Hot Spark in the glove box for a backup. I already have a 3-ohm 100-watt resistor. I should put the 3 ohm resistor between the switched power and the positive terminal on the 0.6-ohm coil, which should make 3.6 ohms of combined resistance and be safe for points. Bypass the resistor and use the key-switched power directly to the points and condenser/hot spark trigger. I already have these items and don't want to buy a second Pertronix 2 trigger.
Sound feasible? Thanks.
SVG223
post Apr 25 2025, 05:05 PM
Now I'm thinking about increasing the gap to something like 0.035". I probably won't notice the difference.
- Lo-Fi Version Time is now: 29th April 2025 - 07:21 AM
