Chad911sc |
Member ![]() ![]() Group: Members Posts: 68 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States ![]() |
So after 5 long months of work, I finally have the 2056 built and installed. (IMG:style_emoticons/default/piratenanner.gif)
I have a couple questions about the 123 4RV distributor. I haven’t hooked it up to power yet, but from my understanding, you hook up only the red wire and then power the ignition and a light should come on in the body of the distributor. 1) Since our motors go in a CW direction, the first movement of the distributor goes clockwise until the light turns off? Then CCW until the green light comes on? Correct? 2) The engine has dual carb Webber 40’s/Web cam 86a/Mild port and polished stock valve heads. My question is what setting should I use on the distributor? From what I see it looks like curve #3. Does this sound right? 3) Do I use the vacuum port on the distributor body to the base of one of my carbs, or do I plug it off, or do I leave it open? Thanks in advance for any info! Attached thumbnail(s) ![]() ![]() ![]() ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Curve 3 looks fine for an initial setting to me.
You shouldn't be "overtimed" to start with. Where is there a difference between #5 and #6? Those have 7-8 degrees more mechanical. They look like what a "normal" water pumper would want. It is odd that the other curves besides 3 have either 22 or 30 degrees mechanical. Your engine compartment is closing on "World Class" (IMG:style_emoticons/default/first.gif) I especially like the CF air filter hats with color matched "bling" I'd bet you're looking for the plastic washers in a lighter hue of blue... Might be able to paint to match! Nicely done Sir! |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,858 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
dupe
Lo-Fi Version | Time is now: 29th April 2025 - 01:45 PM |
