A question for you 6 owners, 914-6 Tune up |
mr914 |
Jan 28 2003, 05:32 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
How do you do a ignition tune up on a 6? (IMG:style_emoticons/default/huh.gif)
I see the dizzy way down there in the front of the motor... Do you have to drop the engine out to get to it, or do you need to find an accomplished 12 year old? How many have modified the firewall for access? |
mskala |
Jan 28 2003, 06:49 PM
R Group: Members Posts: 1,928 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
This topic has been (IMG:style_emoticons/default/smash.gif) over on another list.
I don't think firewall changes are necessary, but some do. You will need to be able to feel for things like the nut for the clamp to adjust it, and the nut that will allow you to remove the whole thing. You will need to adjust more often if you have the original points system, which wears, but you will find that if you have the original Marelli dist (very tall cap), there are no 'points replacement' systems out there, so people switch to a Bosch equivalent ($$). I myself was lucky to find a marelli modified with a prototype optical system and I use that. Set the engine at TDC #1 and note where the rotor is pointing, to within a few degrees. Remove the nut that holds the whole distributor in and just pull it out (oh yeah, remove the wire going to the points first). The gear has very few teeth, so you won't have to work hard to get it back in the same position. Set the points gap on the bench. Once you get confident and know where things are, you could probably regap the points while it's in the car, since the exact gap is not important (CD system). Adjust dist with the engine off so the points to open right at TDC #1. Then time to 35 degrees at 6000 RPM. There are markings on the flywheel (Z1 for TDC, 35 for 35), since the pulley is impossible to see in a 914. Mark S. '70 914-6 |
Lo-Fi Version | Time is now: 15th January 2025 - 10:19 AM |
