plugging air pump holes, anti- seize or pipe dope |
Triaddave |
Feb 20 2005, 12:22 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
i have a head from a later car that had air pump. i have the hex head bolts (m10 x 50mm x 1.0 mm) to close the holes. should i use some kind of sealant on the threads?
the hex head bolts need to be turned to correct angle so as to clear the manifolds, which is good because they can not back out. what do you think i should do? |
Bleyseng |
Feb 20 2005, 12:40 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I thought you could use the 10mm valve adjusters in the holes with a high temp sealant.
Geoff |
Lo-Fi Version | Time is now: 21st December 2024 - 11:47 PM |
