plugging air pump holes, anti- seize or pipe dope |
Triaddave |
Feb 20 2005, 12:22 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
i have a head from a later car that had air pump. i have the hex head bolts (m10 x 50mm x 1.0 mm) to close the holes. should i use some kind of sealant on the threads?
the hex head bolts need to be turned to correct angle so as to clear the manifolds, which is good because they can not back out. what do you think i should do? |
Allan |
Feb 20 2005, 01:19 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Oh that's great. I don't know how to add that. I'm assuming that there is a hose attached to it? Where does the other end go? Is it done on both heads?
Lo-Fi Version | Time is now: 21st December 2024 - 10:58 PM |
