> plugging air pump holes, anti- seize or pipe dope
Triaddave
post Feb 20 2005, 12:22 PM
i have a head from a later car that had air pump. i have the hex head bolts (m10 x 50mm x 1.0 mm) to close the holes. should i use some kind of sealant on the threads?
the hex head bolts need to be turned to correct angle so as to clear the manifolds, which is good because they can not back out. what do you think i should do?
Allan
post Feb 20 2005, 01:25 PM
Teenerless Weenie
So if I don't do this my valve covers will leak and the push-rod tube seals will blow out?
Triaddave   plugging air pump holes   Feb 20 2005, 12:22 PM
Headrage   I'm going to be doing this as well but havent ...   Feb 20 2005, 12:33 PM
Bleyseng   I thought you could use the 10mm valve adjusters i...   Feb 20 2005, 12:40 PM
Aaron Cox   can you just cut them off and weld em shut??   Feb 20 2005, 12:45 PM
Bleyseng   only if the heads are off, then you can have then ...   Feb 20 2005, 12:50 PM
Headrage   ...   Feb 20 2005, 01:14 PM
Aaron Cox   http://www.914world.com/bbs2/uploads/post-2-110412...   Feb 20 2005, 01:17 PM
Headrage   Oh that's great. I don't know how to add ...   Feb 20 2005, 01:19 PM
Aaron Cox   ...   Feb 20 2005, 01:22 PM
Headrage   So if I don't do this my valve covers will lea...   Feb 20 2005, 01:25 PM
Aaron Cox   ...   Feb 20 2005, 01:26 PM
Headrage   What size is the fitting? Can I get directions on...   Feb 20 2005, 01:30 PM
Type 4   Use Set Screws with hex driver and locktite   Feb 20 2005, 01:54 PM
Rhodes71/914   Allen- to not hijack this thread any more I posted...   Feb 20 2005, 02:47 PM
Headrage   Thanks, will look.   Feb 20 2005, 02:54 PM
Triaddave   thanks for the input to all. you are right about t...   Feb 20 2005, 04:27 PM
Aaron Cox
- Lo-Fi Version Time is now: 21st December 2024 - 11:37 PM
