Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
The nut comes off ok but the driver side rear shock bolt on the trailing arm is rusted solid and I can't get it off. Tried some heat, liquid wrench, hammer+drift (made the biggest impression on my hand when I missed...), and a pipe wrench. The pipe wrench sorta rounded the head a bit, but no movement? How do I remove this?
I was going to remove the trailing arm (with shock attached) and see if my local machine shop can press it off. Not sure if they can or it would damage the trailing arm. Also thought about grinding off the head, removing the shock, then taking it to the machine shop for pressing. HELP!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Thanks, Spoke |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Grease them up when you finally get them out and re-install.....
Lo-Fi Version | Time is now: 26th June 2024 - 07:03 AM |
