How To Remove The Rear Shock Bolt?, The One On The Trailing Arm |
Spoke |
Feb 22 2005, 06:40 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The nut comes off ok but the driver side rear shock bolt on the trailing arm is rusted solid and I can't get it off. Tried some heat, liquid wrench, hammer+drift (made the biggest impression on my hand when I missed...), and a pipe wrench. The pipe wrench sorta rounded the head a bit, but no movement? How do I remove this?
I was going to remove the trailing arm (with shock attached) and see if my local machine shop can press it off. Not sure if they can or it would damage the trailing arm. Also thought about grinding off the head, removing the shock, then taking it to the machine shop for pressing. HELP!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Thanks, Spoke |
riverman |
Feb 22 2005, 08:41 PM
Learn As I Go Group: Members Posts: 449 Joined: 18-January 05 From: Kitchener, ON Member No.: 3,466 |
I had this same problem about a week ago and I got mine off. I soaked the threads in penetrating oil and left it overnight. Then I put a 27mm closed end wrench on the nut and then whacked the wrench with a big rubber mallet. Every time I hit it, the nut squeaked a little and I wasn't sure it was coming off, but it eventually did.
Lo-Fi Version | Time is now: 26th June 2024 - 07:18 AM |
