> 914 Heater, any solutions ?
MecGen
post Feb 25 2005, 05:29 AM
8 Easy Steps
Hi people
Lots of good mods here, on the forum.
Has anybody found, used a heater sytem for the air cooled motor? Oil cooler for example? I am always scarred to plumb oil into the tub...it is a 914. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Electric heaters, word is they just don't work.
I don't have stock heat exchangers any more.
Anybody have a decent solution
Thanx 1000 x
Cheers
Joe
(IMG:http://www.914world.com/bbs2/html/emoticons/rock_band.gif)
scotty914
post Feb 25 2005, 10:22 AM
suby torque rules
2 1800 watt hair dryers, no way first they cant be over 1500 watts and use a normal plug, but that does not mean he did not change a plug. 2, that is one noisy way to get heat. 3, thats 3600 watts at 120 volts, or 30 amps at 120 volts, then lets say he had an inverter running from the alt and battery and it was 100 % effecent, that would be 300 amps at 12 volts, or enought to drain the battery flat in 15 minutes even with the alt charging it.
what i used was a coleman heater designed for use in cars, as a emergency heater if you broke down in winter, i mounted it under the dash. between the seats aiming at the back, it was enough to help my leaky HE at 20 to 30 outside temps, here is the one i used in my car. and i never had a problem the 914 is leaky enough to avoid CO stuff
but coleman also makes a 1100 btu heater, as they put it "for rec use in enclosed spaces. that would work by it self to heat a car
MecGen   914 Heater   Feb 25 2005, 05:29 AM
trekkor   Seems to me that Dan Root makes heaters out of she...   Feb 25 2005, 05:58 AM
MecGen   Excactly what I tryed to do 10 years ago, my exhau...   Feb 25 2005, 06:21 AM
BarberDave   http://www.914world.com/bbs2/html/e...   Feb 25 2005, 06:32 AM
Bleyseng   If you are running a header fab something around t...   Feb 25 2005, 08:48 AM
sgomes   where is Otmar on this one? I believe he uses two...   Feb 25 2005, 08:57 AM
CHAFF   I'm in the process of refurbing and installing...   Feb 25 2005, 09:45 AM
Rhodes71/914   I took a ride in a members car that had an electri...   Feb 25 2005, 09:59 AM
scott thacher   2 1800 watt hair dryers, no way first they cant be...   Feb 25 2005, 10:22 AM
Gary   I have one of these Espar D1LC heater in a box. Bo...   Feb 25 2005, 02:45 PM
SirAndy     Feb 25 2005, 03:41 PM
don9146   <...   Feb 25 2005, 03:43 PM
SirAndy   <...   Feb 25 2005, 03:52 PM
MecGen   You people rock !!!
- Lo-Fi Version Time is now: 6th January 2025 - 03:55 PM
