SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,200 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Back by popular demand, Sir Andy's "HOW TO" series presents:
HOW TO: Run the fuel pump for carb conversions There are numerous tech. articles out there that cover this issue. When you switch from the stock FI to carburetors, you have to install a low pressure carb fuel-pump. But, since the FI fuel pump is controlled by the FI brain, removing the brain means the wires to the fuel pump won't give you 12V ... There are a lot of "band-aid" solutions out there, some people remove the pump relay and add a jumper there, others even run the pump off the coil! While all those solutions work (more or less) they all lack one thing, you're now running the pump without a relay! (and in case of the coil, without fuse as well) The best (and also easiest!) solution is to trick the relayboard into believing that the FI-Brain is still connected ... And it's as simple as connecting one wire from the 4-prong FI connector to ground. You keep the stock fuel pump relay and fuse and you use the stock wires to power the new fuel pump. Below you'll see 2 pictures showing how to attach the wire. on the pump side, simple make 2 more extension wires with "male" connectors on one end and plug them into the stock (roundish) plug for the stock fuel pump. No need to hack into the original harness!!! This install is clean and simple! (and cheap!) In the pics below the thick red wired replaces the FI-Brain ... (IMG:style_emoticons/default/smash.gif) Andy (IMG:http://www.914world.com/bbs2/uploads/post-11-1109378319.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-11-1109378417.jpg) |
SirAndy |
QUOTE(redshift @ Feb 25 2005, 04:51 PM) Do you have more pics? Other angles? yes ... QUOTE Can a person with a wire, and two crimpy ends do this in less than a minute? yes ... QUOTE Who took that picture? me, myself and i ... QUOTE Whats up with the green wire pulled out of the harness in photo #2 ? the engine harness is from my old 1.8L which had the green wire for the heater blower in the engine harness. my car now has a '74 (?) main harness and the wires (green/brown) for the heater blower are spliced off the the main harness instead. i didn't want to cut the hard plastic protection of my engine harness to remove the wire but i had to take it out of the connector as the layout of the prongs changed between '70 and '74 ... QUOTE wouldn't a good German use a brown wire? yes, but i didn't have any handy besides the red one. some day, i'll change it to brown. not on top of my list right now ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
Lo-Fi Version | Time is now: 27th April 2025 - 07:24 PM |
