machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
the right side of the motor (3&4) quit firing. checked the plug leads but doesn't change anything.
could there be a problem with the carb? when I disconnect the linkage and push on the left carb the motor revs but when I push on the right carb it does not rev faster, only sounds different from opening the throttle plates. sorry, I'm a carb newbie. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I would go with a stuck float on this one--ifn you are opening up the plates while the engine is running and no change in rpms--means your mains are not flowing fuel either---mine did this only the opposite--mine stuck open and the pump was pumping all it could into those two cylinders, completely flooded it--gave it a good whack with a brass mallet and fine ever since....
Lo-Fi Version | Time is now: 26th June 2024 - 01:01 AM |
