> End Play, It don't move
Allan
post Feb 27 2005, 09:26 PM
Teenerless Weenie
I finally got my son over to help me set my crank end play. Bolted up the flywheel with the original shims under it and for the life of me we can't get the crank to slide at all. I'm pretty sure that it is supposed to be .003-.005. What is the best way to push and pull to get it to move?
Thanks
r_towle
post Feb 28 2005, 09:57 PM
Custom Member
that would depend on what you did to the case, crank, and bearings etc...
This has really got to be right. its worth getting the right shims.
Take one out and see what you get with the hammer (soft)
Also, how is your dial indicator mounted...if it is not mounted securely it will bounce and not read it right....
Rich
Headrage   End Play   Feb 27 2005, 09:26 PM
Bleyseng   Do you have the proper tools to set it? It doesn...   Feb 27 2005, 10:01 PM
Demick   Remove all the shims, bolt up the flywheel, and me...   Feb 27 2005, 10:05 PM
Headrage   ...   Feb 27 2005, 10:13 PM
Joe Sharp   Allan. you need .004, anything less is unaccetable...   Feb 27 2005, 10:14 PM
Headrage   Thanks Joe. I'm gonna hang it up for tonight....   Feb 27 2005, 10:17 PM
Headrage   Okay, I'm back at it again. I put the 2 large...   Feb 28 2005, 08:48 PM
SLITS   Hey Allan, the barbarian here....when I setup end ...   Feb 28 2005, 09:27 PM
r_towle   i was gonna say a rubber mallet,,,but i figured i ...   Feb 28 2005, 09:38 PM
SLITS   <...   Feb 28 2005, 09:41 PM
Headrage   Okay, using the brute force method, it looks to be...   Feb 28 2005, 09:44 PM
r_towle   to small   Feb 28 2005, 09:47 PM
r_towle   gentle.....i use a rubber mallet....slits said sof...   Feb 28 2005, 09:48 PM
Headrage   Well I can get .005 if I just push on it a little ...   Feb 28 2005, 09:52 PM
r_towle   that would depend on what you did to the case, cra...   Feb 28 2005, 09:57 PM
Headrage   I had the case align bored and the crank polished....   Feb 28 2005, 10:04 PM
SLITS   The case work would probably have more to do with ...   Feb 28 2005, 10:42 PM
Headrage   Well I'm going to leave it alone for tonight a...   Feb 28 2005, 10:45 PM
Joe Sharp   Allan: If the crank is moving after you put in all...   Feb 28 2005, 10:49 PM
Headrage   Okay, let's try this again. I went to the loc...   Mar 1 2005, 04:31 PM
SLITS   <...   Mar 1 2005, 05:20 PM
Headrage   Oh I've got that covered. Fuel lines going in...   Mar 1 2005, 05:39 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:30 PM
