> FI Intake Runner Gasket Install, cooling tin in the way?
Bruce Allert
post Mar 4 2005, 12:42 AM
Hellions asleep
After re-installing the cooling tin (after painting) I put the phenloic intake gasket on the head to see how the fit was going to be. The tin has 3 tabs that extend under the gasket. Is the gasket supposed to go onto the head first then the tin? When I took the intakes off, the gaskets came with them. I figure the gasket should go over the tin but wouldn't that be cause for a vacuum leak??? Here's the tabs on the tin I'm speaking of.
........b
Dave_Darling
post Mar 4 2005, 01:29 PM
914 Idiot
I don't recall the left and right arrowed spots on the engine tin interfering with the gasket on my car. The middle arrow would, if there were not a recess in the cylinder head for the tin to slide into.
--DD
Bruce Allert   FI Intake Runner Gasket Install   Mar 4 2005, 12:42 AM
scott thacher   either trim the tin or the gasket, i personally wo...   Mar 4 2005, 12:57 AM
Bruce Allert   Thanks Scott on both answers!   Mar 4 2005, 09:28 AM
Dave_Darling   I don't recall the left and right arrowed spot...   Mar 4 2005, 01:29 PM
Bruce Allert   I found the left arrow'd tab did not interfere...   Mar 4 2005, 03:53 PM
StratPlayer   When installing these gaskets do you use any gaske...   Feb 26 2006, 11:37 PM
MattR
- Lo-Fi Version Time is now: 6th January 2025 - 07:22 PM
