> FI Intake Runner Gasket Install, cooling tin in the way?
Bruce Allert
post Mar 4 2005, 12:42 AM
Hellions asleep
After re-installing the cooling tin (after painting) I put the phenloic intake gasket on the head to see how the fit was going to be. The tin has 3 tabs that extend under the gasket. Is the gasket supposed to go onto the head first then the tin? When I took the intakes off, the gaskets came with them. I figure the gasket should go over the tin but wouldn't that be cause for a vacuum leak??? Here's the tabs on the tin I'm speaking of.
........b
Bruce Allert
post Mar 4 2005, 03:53 PM
Hellions asleep
I found the left arrow'd tab did not interfere but the right one sure did. I cliped it and it fits fine.
Not sure how the normal way is to re-install the runners... I installed the plenum then pushed the runners into it. T'was a beotch to say the least. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Had to use a wee bit O' lube!!! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
.......b
Bruce Allert   FI Intake Runner Gasket Install   Mar 4 2005, 12:42 AM
scott thacher   either trim the tin or the gasket, i personally wo...   Mar 4 2005, 12:57 AM
Bruce Allert   Thanks Scott on both answers!   Mar 4 2005, 09:28 AM
Dave_Darling   I don't recall the left and right arrowed spot...   Mar 4 2005, 01:29 PM
Bruce Allert   I found the left arrow'd tab did not interfere...   Mar 4 2005, 03:53 PM
StratPlayer   When installing these gaskets do you use any gaske...   Feb 26 2006, 11:37 PM
MattR
- Lo-Fi Version Time is now: 6th January 2025 - 06:47 PM
