Thermostat/Flaps, R they necessary? |
martinef1963 |
Mar 6 2005, 07:58 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
I have a question and would like a "wide" view point from this forum on Thermostat/Flaps on a 914
Mine are missing - and I've rcvd one comment saying that they are NOT really necessary. Can I get some inputs on this topic - while doing some work on my car (I'm a newbie) yesterday - I noticed that the thermostat, thermostat housing, and thermostat cable are missing - only have the pulley. In addition - where the EFFIN are these flaps? Cause if they are not needed and they are in place - they could be a problem, right? thanks (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
SirAndy |
Mar 6 2005, 02:07 PM
Resident German Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you NEED the flaps but you dont need the thermostat !!! the flaps control how the cooling air is channeled over your cylinders and over the oil-cooler. if the flaps are removed your oil-cooler will not get any air-flow !!! but you can savely remove the thermostat and cable. what that does is, it'll *park* the flaps in full cooling position (max. air to the coil-cooler and cylinders) if you do this, it'll take longer for the engine to warm up but you'll always get max. cooling ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy PS: do *not* remove the pulley wheel !!! the bolt that holds the wheel goes through and inside the case. if you remove the pulley wheel, you'll have a *major* oil leak ... |
Lo-Fi Version | Time is now: 24th June 2024 - 06:59 AM |
