SirIke |
Newbie ![]() Group: Members Posts: 11 Joined: 17-February 05 From: Houston,TX Member No.: 3,620 ![]() |
Let me start off by saying thanks for the info about the oil pressure on my car. We change out the oil sender and cleaned the oil release springs. This solved the proble of what was making the oil pressure light come on. Now we need your help again. We need to know what position the bar on top of the engine that open and close the cooling tins. We think open is where the tap on the bar is straight up and down. and close is when the tap on the bar is back toward the rear of the car. Is this correct?
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
In houston, don't worry about the thermostat. Just disconnect the cable from the flappers all-together and it will be set on full cooling. The thermostat is just to help the engine warm up faster. Not a problem in a warm climate, such as Texas. Sounds like you're thinking it will solve your overheating problems. It won't. Unhook it if you're in doubt.
Lo-Fi Version | Time is now: 24th June 2024 - 07:45 AM |
