Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I bought a speedo drive seal from GPR last week and it looks like the shifter seal only smaller. The haynes manual shows an 0-ring. Does anyone know which is correct before I try to replace it. The part number I have for the new one from GPR is 999.113.036.50.
Here is a crappy pic. Attached image(s) ![]() |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
There are two seals: an O-ring that seals the drive housing to the tranny case, which you can see when you remove the bolt and pull the drive out of the tranny, and a seal (which you already have) that seals the rotating shaft. You can see the seal when you unscrew the bottom half of the drive housing from the top half.
I can look up the number for the O-ring when I get home in a couple of hours. I know Pelican has the O-ring, but I don't see it on their site. It will come up if the Porsche part number is typed in though. Andrew |
Lo-Fi Version | Time is now: 26th June 2024 - 09:14 AM |
