> Emergency Suspension Question, coil-over thrust bearing???
Chris Julian
post Mar 17 2005, 02:05 PM
Hi all,
My 914-8 is at Custom Alignment in Mt View, CA for a final alignment prior to this weekends autocross @ Marina. I’m having Custom Alignment perform a four-corner alignment and four-corner balance. They just called with an issue—the front RS coil-over struts are not properly rotating on the monoball mounts. Seems the monoball is too sticky and is not allowing the front wheels to track properly. They suggested using a needle thrust bearing between the coil spring hat and the monoball. Is this a common component that I just left out?
Thanks in advance,
Chris
Chris Julian   Emergency Suspension Question   Mar 17 2005, 02:05 PM
Mueller   yes...you want them.....not too many people run th...   Mar 17 2005, 02:12 PM
phantom914   Do you have a picture of your set-up? I have Groun...   Mar 17 2005, 02:13 PM
Mueller   oh yea, it might be overkill, but I installed thes...   Mar 17 2005, 02:21 PM
Chris Julian   Thanks Mike. I ordered roller thrust bearings fro...   Mar 17 2005, 03:45 PM
Mueller     Mar 17 2005, 03:47 PM
fiid   http://www.914world.com/bbs2/...   Mar 17 2005, 04:03 PM
SirAndy   <...   Mar 17 2005, 04:19 PM
TimT
  Mar 17 2005, 04:32 PM
TimT   nutter   Mar 17 2005, 04:33 PM
Chris Julian   OK now I did not think of putting the bearing at t...   Mar 17 2005, 04:41 PM
Mueller   <...   Mar 17 2005, 05:54 PM
- Lo-Fi Version Time is now: 26th December 2024 - 11:25 PM
