Emergency Suspension Question, coil-over thrust bearing??? |
Chris Julian |
Mar 17 2005, 02:05 PM
Member Group: Members Posts: 159 Joined: 19-March 04 From: SF Bay area Member No.: 1,821 |
Hi all,
My 914-8 is at Custom Alignment in Mt View, CA for a final alignment prior to this weekends autocross @ Marina. I’m having Custom Alignment perform a four-corner alignment and four-corner balance. They just called with an issue—the front RS coil-over struts are not properly rotating on the monoball mounts. Seems the monoball is too sticky and is not allowing the front wheels to track properly. They suggested using a needle thrust bearing between the coil spring hat and the monoball. Is this a common component that I just left out? Thanks in advance, Chris |
SirAndy |
Mar 17 2005, 04:19 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
that engine of yours has made that drive numerous times without any trouble ... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Andy |
Lo-Fi Version | Time is now: 26th December 2024 - 11:56 PM |
