machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
Haven't had a problem with the battery running down yet but...
if I wanted to give a quick charge at the track, could I... run an inverter in the truck to power a small 10 amp charger, to boost the battery between runs? Will it run my truck battery down in a 1/2 hour? How big of an inverter will I need to run the charger? I've checked different brands specs but they don't seem to tell what the power consumption is. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
...just use jumper cables to connect it to the truck battery ? yes... or if you even think it might be an issue, get a solar panel charger and just always connect it. Pegasus sells some nice quick-disconnect grid-power battery connectors -- the dry-cell formula-car guys use those a lot... |
Lo-Fi Version | Time is now: 1st July 2024 - 03:59 AM |
