stupid human questions, 12v => 110v => 12v |
machina |
Mar 18 2005, 12:58 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Haven't had a problem with the battery running down yet but...
if I wanted to give a quick charge at the track, could I... run an inverter in the truck to power a small 10 amp charger, to boost the battery between runs? Will it run my truck battery down in a 1/2 hour? How big of an inverter will I need to run the charger? I've checked different brands specs but they don't seem to tell what the power consumption is. |
scotty914 |
Mar 18 2005, 01:12 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
sorry tony, its 10 amps at 12 volts not 120
so 10 amps at 12 is 1 amp at 120 volt or 120 watts so the inverter needs to put out 120 watts at 120 but as tony mentioned there is a loss but you average 300 watt inverter can do it with out a problem but i would just use jumper cables or get one of those jump packs, that way you can have a small compressor for tire pressure changes as well, if you buy one with it |
Lo-Fi Version | Time is now: 1st July 2024 - 03:53 AM |
