sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
I've got stubs and hubs from a 69 911 and a 915 tranny from a an 85. When I went to measure up the axle flanges from the 915 it matches the diameter of the stubs from the 69. Only thing is, is the 69 stubs mount the cv's with 4 bolts and 2 pins. What I was thinking is to have the 2 roll pin holes welded up and then drilled and tapped with the same size bolt hole as the other 4 bolts.
btw the 915 axle flanges and the stubs both use 10mm bolts. Has anyone done this type of modification and on a safety stand point is this something that would be avoided. |
Otmar |
2000 Amps in a 914 ![]() ![]() Group: Members Posts: 174 Joined: 3-March 03 From: Corvallis, OR, USA Member No.: 387 ![]() |
I think only the 930 CV's are thicker. The Bus CVs are larger diameter than the 914/bug CVs. Let me look around a bit: 914 CV's 90 mm at flange (93mm body) Just measured. Bus CVs 100mm (from the web) The above two are about the same thickness (from experience). "930' CV's 108mm (from above) and thicker (from experience). These are used in off road applications for their strength and larger angular capability. hth, |
Lo-Fi Version | Time is now: 29th June 2024 - 02:08 AM |
