ChrisFix |
Member ![]() ![]() Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 ![]() |
I've been restoring a pair of pre '75 round OEM fog lamps I bought used and in pieces. I've cleaned and repainted everything, and with the help of Karl's repro seals am ready to reassemble.
I'm guessing the wire spring clips are supposed to hold the lens/reflector assembly to the front bezel, but haven't figured out how they accomplish that task. Also, does the seal go around both the lens and reflector, holding them together as an assembly? Any guidance or links to an exploded view? Thanks!! |
ChrisFix |
Yes, I've found the factory mounting holes. They already have bolts intalled from the factory, so they didn't look to me like they were available mounting holes for the fogs - I figured the bolts were holding something together! Anyway, I have the OEM mounting bracket with the fog lights, I just need to pull the bolt that's already on the car and put it through the bracket and I'm done (I hope). I've wired up a light already (un-installed) and it works fine, so the hard stuff should be behind me.
Lo-Fi Version | Time is now: 25th June 2024 - 12:57 AM |
