wrpspddrvr |
Member ![]() ![]() Group: Members Posts: 333 Joined: 22-December 04 Member No.: 3,317 Region Association: None ![]() |
As some of you may be aware, for the last 4 days I've been in the middle of installing my XR700 ignition (the one hour install that's taken about 10 so far). I've gotten it so that the rotor points at the TDC #1 mark on the dizzy while the impeller is at the TDC #1 mark.
When turning the key, I can get the car to catch here and there, but it never runs. It coughs and sputs, but never actually runs. I know my timing is probably way off, but how am I supposed to change it if it doesn't run? Do I just turn the dizzy until it runs, or....?? Also, before timing I need to calibrate the optical tirgger to the shutter. The directions say the LED should light up when the leading edge of the slit in the shutter aligns with the light beam, but one of the members here said the LED is infrared, therefore I won't be able to see it. How am I supposed to know when it's aligned properly? Unfortunately, it's raining out there, so I can't work on my car right now. It's not so much that I care about getting wet as that I don't want water in my dizzy. Sigh. So hopefully any advice/tips given will contribute to the work I'll do tomorrow. Thanks all, Cole (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Cole, I wish I was there to help man. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
I haven't ever installed a Crane unit before. I have heard good things about them though. At this piont, I would almost say put those points back in. Hey, stupid question, you took the condensor off right? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:48 AM |
