Kinda OT: Ford tach in my 914, What the hell am I up to |
DNHunt |
Mar 24 2005, 07:36 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Follow me on this you guys.
My ignition is a Ford EDIS system off of an Escort. (Don't laugh it works) Wasted spark, no dizzy and a 2 coil 4 tower coil pack. The problem is that the 914 tach is triggered off of the negative side of the stock coil and it won't work with the EDIS system. So, I snagged an Escort tach at a pick and pull and I'm going to swap the guts into an extra 914 tach. I just want to verify the connections. It has 3 connectors. Ground and signal in are self explanatory. The 3rd one is labelled B. This has to be switched 12V, right? Thanks Dave |
fiid |
Mar 24 2005, 10:03 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Crap. I'm going to have the same problem - although I do have an aftermarket VDO tach which I plan to use - but I need to sort out moving all the lights out of the other dials.
Lo-Fi Version | Time is now: 25th June 2024 - 09:41 PM |
