DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Follow me on this you guys.
My ignition is a Ford EDIS system off of an Escort. (Don't laugh it works) Wasted spark, no dizzy and a 2 coil 4 tower coil pack. The problem is that the 914 tach is triggered off of the negative side of the stock coil and it won't work with the EDIS system. So, I snagged an Escort tach at a pick and pull and I'm going to swap the guts into an extra 914 tach. I just want to verify the connections. It has 3 connectors. Ground and signal in are self explanatory. The 3rd one is labelled B. This has to be switched 12V, right? Thanks Dave |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
Crap I'm going to have the same problem. Right now I'm triggering my tach off the coil. I tried using the tach signal from my aftermarket ECU (square wave 5v or 12v - can't remember which) and the tach doesn't budge. So I put it back on the coil. I was going to switch to waste-spark this summer, but I forgot that I'll have to deal with the tach again. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
-Ben M. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:08 PM |
