opera guy |
Member ![]() ![]() Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 ![]() |
(IMG:http://forums.pelicanparts.com/uploads4/StrutReinforcement011104770018.jpg)
part 1, 2, and 3 are removed. also, the top end is removed from under the hood. in addition, the tie rod is removed (gonna install TTR), but the strut is stuck to the ball joint. how do i unstuck it? i wanna install new ball joint later next week, and wanna clean up the lower strut housing a little (also wanna install some koni inserts) please help ps. should i do bump steer kit now? will lower the car about 1 inch |
ajracer |
Member ![]() ![]() Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 ![]() |
Just me $ 0.02 worth SINCE I just did this a few days ago.
Let me say that I had followed all the suggests mentioned above and out there, but had little success. So I decided I would attempt to remove the Ball Joint from the A arm and Then try to remove the Ball Joint from the bottom of strut. I used lots of penetration fluid, air chisel, pipe wrench, etc. BUT no luck until I used a torch to heat the ball joint nut and then air chiseled it came loose. Then all I needed to do was place in a vise and heat the bottom of the strut and hammer along with air chisel to break the ball joint loose from strut. It was a difficult and time consuming job, but about two hours later I had both removed and moved on to another project. The Ball Joints were junk from the heat (seems some type of deadly "plastic" in the joint) but saved everything else. Few days later I then got some front suspension parts to replace my RUSTED A-arms and then repeated the same procedure with better success and even spared the ball joints and rubber seals from excessive heat; now I can reuse these ball joints. (According to my 914 friend he states the 914 ball joint hardly ever wear out or fail, not sure if true but they are tight and sealed). Trust this long winded comments might assist you. Allan |
Lo-Fi Version | Time is now: 26th June 2024 - 12:49 PM |
