iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
It's starting to come together, I have been busy fashioning the intercooler and will begin the duct work for the exit air out of the intercooler, I will be pulling the air through the intercooler via 2-7"electric fans and the exit air will be ducted through and past my transmission cooler and out behind the rear bumper. the fresh air will be coming in through a duct in my rear spoiler, I should have it all done in a few days. look at the pictures, the fans will be mounted underneth the IC, I placed them on top so you have an idea of the size of the IC.
Attached image(s) ![]() |
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,727 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
Chappy, did you calc the CFM rate thru this IC unit ? It's a Spearco from Turbonetics , yes ? It looks somewhat borderline flow for the 3.0 ...the fans should help cool everything thru. Remember...too small an intercooler= big pressure drop in boost, you may loose 2 to 3 psi. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Hopefully not the case.
Marty |
Lo-Fi Version | Time is now: 26th June 2024 - 12:21 AM |
