tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
ok, as you all know by now I have a burnt valve, and I think that's it.
however, I'm catching a lot of grief from people saying I should split the case, do everything!!! I understand that if I want this 1.7 to last another 100k miles I do need to do this... however, if I only need to fix what's wrong until next summer/spring... is it ok, to just do the top-end(rings/heads) now? I plan to completely rebuild next summer, or next winter(2004) at the latest, put 96mm pistons with a 71mm(or 78mm) crank, new cam...the works!!! at most I will put 1-3k miles on the engine between now and then. I hardly drive it in the winter... no heater b/c of headers... so, can you do the rings and heads without cracking the case and checking main bearings, rod bearings and everything that will be replaced in a year anyway? I just didn't want to to all of this and have to do it all again when I trick out the engine... (IMG:style_emoticons/default/confused24.gif) |
tat2dphreak |
I'm unsure about the miles... the OD says 40k... which could be 40, 140 or 540!!
and that's assuming it's accurate! and the PO said the engine has been rebuilt once already. I was just going to do the rings to be sure and fix the low compression... but I am thinking I will do the heads, then retest the compression and see if I need to do the rings... it was more of a "why not do the rings?" but then I was thinking that if I did the rings, the case may leak afterward.... I'm going to drop the engine today(my first time, wish me luck), and I want my ducks in a row... |
Lo-Fi Version | Time is now: 24th June 2024 - 07:00 AM |
