How many MPSs are "popped"? |
McMark |
Mar 26 2005, 03:48 AM
I pretty much assume that every MPS I see is either broken or on its way out (diaphragm damage). I'm I right or wrong?
ArtechnikA |
Mar 26 2005, 08:17 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
sorry, but if you did, you would be wrong... we have BTDT through this topic a zillion times. D-Jet is *nothing* like a modern system. it's based on an analog trick. the trigger points make the square wave that drives the injectors. the MPS is a variable-reluctance transformer. it uses vacuum sensing to move an iron core to swallow up more or less of that initial square wave signal. i suppose you *could* build a device that could simulate the characteristics of a variable-reluctance transducer, but it would be hard, and it would not give you the desired effect of working with off the shelf components. D-Jet was a clever analog computing engineering trick for the mid''60's when it was designed. but we've learned a bunch of stuff in 40 years, and we'd never approach that problem that way doing it now. when you approach it with what's available now, you wind up with a MegaSquirt... |
Lo-Fi Version | Time is now: 28th June 2024 - 09:28 AM |
