URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,328 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
When I last left you I had just weighed it and it was just completed enough to get it running, I've now been spending some time getting things sorted out and the little stuff completed. Have a look...
This is the seat belt shoulder bar. The belts wrap around the bar. No tabs to be welded on, no nuts, washers and bolts=lighter. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (I weighed the car with the belts and some other misc. pieces in the car so the weigh will stay the same as I install this stuff.) Attached thumbnail(s) ![]() |
URY914 |
I can reach everything but the exhaust stud nuts from thr top. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
Here you you can see the breater hose layout. I gotta get one of those lightwt gear reduction starters. I also need to raise the rear top shock mounts. Right now I can't lower the springs without bottoming out the shocks. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 01:13 PM |
