sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
I've got stubs and hubs from a 69 911 and a 915 tranny from a an 85. When I went to measure up the axle flanges from the 915 it matches the diameter of the stubs from the 69. Only thing is, is the 69 stubs mount the cv's with 4 bolts and 2 pins. What I was thinking is to have the 2 roll pin holes welded up and then drilled and tapped with the same size bolt hole as the other 4 bolts.
btw the 915 axle flanges and the stubs both use 10mm bolts. Has anyone done this type of modification and on a safety stand point is this something that would be avoided. |
datapace |
Member ![]() ![]() Group: Members Posts: 133 Joined: 19-January 04 From: Atlanta, GA Member No.: 1,579 Region Association: South East States ![]() ![]() |
Nice!
How much were the adapters/spacers from Patrick? I can't seem to find them on their site. It looks like they are only on the inboard side, is there any other spacing you need to do on the stub axle side? The carrera axles and stubs are one piece IRCC right? -Bryan |
Lo-Fi Version | Time is now: 29th June 2024 - 02:12 AM |
