Bruce Allert |
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest ![]() |
Had to put in points cuz the Pertronics took a dump. Had trouble getting the dwell to 45 but made it. Idles great.
Sounds like it's missing intermittanly while driving but I can't feel it. Might be a slight backfire. Timed it to 27 degrees. After reading that so many are adjusting valves to .005 on their 2.0's I figured I'd give it a try. MAN! are they noisey! I'll re-adjust & see what happens. Maybe I goofed somewhere & this might be the cause of it's running crappy. There's new plugs, wires cap & rotor. Getting very tired of working on this thing with no results (whine (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) ) Also have an oil leak in the vicinity of oil cooler. Can seals be installed from the top with the tin off? I sure don't want to pull the engine again (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Might try the electronic ignition again or just go crazy & set it on fire! (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) .........b |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
see if there is someone in your area with a lift you might use for a few hours (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) , and save you neck and back. when the values are done "cold", how cold does that have to be? can you get away with luke warm to the touch, or does the car have to sit overnight?
k |
Lo-Fi Version | Time is now: 24th June 2024 - 07:47 AM |
