ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,545 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
I'm about to install the Mahle Euro (flat top) pistons and cylinders. I know that it is critical to have the pistons facing the correct direction relative to the flywheel. I'm used to seeing an arrow on top of the piston that is supposed to be pointed toward the flywheel. These Mahle pistons have no such marking.
This picture shows the top of the piston. Is that funny little symbol supposed to represent a crankshaft & flywheel? Is it critical which side faces the flywheel end or just that all the pistons are the same? I'm hoping someone answers quick - I'd love to get the heads on tonight! Attached image(s) ![]() |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
silly rabbit tricks are for kids. the picture of the piston top shows you a picture of the flywheel. If using the piston as it is in the picture the flywheel would be on the right. which would be correct for cylinder #1.
Lo-Fi Version | Time is now: 26th June 2024 - 11:06 AM |
