MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
I have my freash 2056 in the floor right now and Im trying to build oil pressure outside the car to make sure I have no problems. Well I have a problem.
Rocker assemblies are out, plugs are out, and its filled with oil. With the transmission off the flywheel cranks pretty freely. I can turn it over by hand with no problem. Then I bolt up the transmission and try to bump it with the starter and it wont budge. Whats causing this? The trans is out of gear and the starter works when I hook up 12v. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
MattR |
I am using jumper cables from the battery terminals to the starter and case bolts. The surfaces are clean, and the battery is charged. I have the starter there with an "engine start" button and tried that. No dice (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Lo-Fi Version | Time is now: 23rd June 2024 - 01:24 PM |
