MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
I have my freash 2056 in the floor right now and Im trying to build oil pressure outside the car to make sure I have no problems. Well I have a problem.
Rocker assemblies are out, plugs are out, and its filled with oil. With the transmission off the flywheel cranks pretty freely. I can turn it over by hand with no problem. Then I bolt up the transmission and try to bump it with the starter and it wont budge. Whats causing this? The trans is out of gear and the starter works when I hook up 12v. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
Does the tranny turn over when in neutral using the input shaft? When you bolt the tranny on and put it in gear can you turn the engine with one of the axel stubs? Sounds like something is getting jammed when you bolt the tranny on?
Lo-Fi Version | Time is now: 23rd June 2024 - 01:10 PM |
