fi harness, correct plug-in side |
martinef1963 |
Mar 26 2005, 09:50 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
have a quick qestion. was putting my harness back and was wondering - how could I tell if i was putting the mps/fi injectors/tps...etc....
is there a right/wrong side.... |
JeffBowlsby |
Mar 30 2005, 07:37 PM
914 Wiring Harnesses Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Nothing, if you install it correctly. Both FI harnesses have only 4 wires for the TPS. The 5 pole variety only has 4 wires in it if you will look (1 cavity is empty). The trick is to get the 4 pole plug in the 5 pole TPS correctly and there are only 2 ways that can work. One of them will be correct. The 5 pole TPS has the wire numbers on it too so you can match them up that way with the wire numbers on the harness. Or bestter yet...just use the 4 pole TPS...like he said.. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:20 PM |
