Mallory Unilite question..., springs when stock??? |
Mueller |
Mar 30 2005, 09:33 PM
So McMark thinks the advance is not happening quick enough, upon receiving my Mallory Unilite, all I did was replace one spring inside (red I think) with the recommended gray spring....I "thought" the other spring inside was gray so then I'd have gray/gray combo....now I'm second guessing my springs (at work right now so I cannot check)
thought someone might know (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) thanks |
Aaron Cox |
Mar 30 2005, 09:36 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i changed both out. they are not the same as installed
your advance should be done by about 2800 (depending on initial advance at idle ) i switched both out...mucho more responsive |
Lo-Fi Version | Time is now: 24th June 2024 - 11:36 PM |
