ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,546 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
This started out as this topic: http://www.914world.com/bbs2/index.php?act=...=ST&f=2&t=28067
It seemed like a good idea to start a new thread with different subject. The 2.0L engine I'm building is using stock crank & rods with stock size (94mm) Euro flat top pistons. My understanding from other topics is that when you build such an engine you get slightly higher compression than stock because of the flat top piston, but you basically don't need to change anything else. When I put the first piston & cylinder in place I used the .007" barrel gasket that was included with the overhaul gasket set. I measured the distance from the top of the piston at TDC to the top of the cylinder at .022" I don't have the actualy head cc measurement, but the paperwork for getting my heads done says they were cut .005". I don't know for sure if that is just this time or if the final cut is .005 including any cuts done during previous rebuilds. Using the math formulas and various calculators mentioned in the previous topic, I figure that if I assemble the engine this way I'll end up with a compression ratio of about 1:8.2 or 1:8.4 This engine will use the stock D-jet FI. So my question is: is it ok to assemble the engine with what I have or is this compression too high? If it's too high, what should I be shooting for with Euro flat top pistons? If I need different barrel spacers to reduce the compression, it's fine with me, but I don't want to just pick some number out of a hat or build it this way without knowing that it's ok. |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
Before you measure your deck height make sure the gasket surface on the block & cylinders are spotless clean. I was getting measurement varied from cylinder to cylinder by .008. I cleaned the registers and they are within .002.
Here some info on measuing deck height form the same Corvair site. About 2/3 of the way down the page:http://home.hiwaay.net/~langford/corvair/t...trial_assy.html |
Lo-Fi Version | Time is now: 28th June 2024 - 10:35 PM |
