Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Well finally done with the floorpan, finished last night, but to dark to take picks. As you can see, the floorpan was virtually rust free! The only rust was surface, which, if I spent more time cleaning, It would all be bare metal. But I figured that the por15 would change the surface rust to non existant rust, so I didnt spend the time. I did clean off any loose surface rust with eather sand paper, or a wire wheel.
Enjoy!! (IMG:style_emoticons/default/wavey.gif) Attached image(s) ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,191 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(Andyrew @ Jun 19 2003, 10:15 AM) And my next project.. is that lower hole in the fender or the frame rail? can't really tell from the picture. if it is in the frame-rail, make sure to check the frame from underneath, the acid will drip into the rail and rust the bottom too. if you just close the top, the bottom rust will have plenty of time to eat on your car ... if you're not sure, cut the top open, big enough to get a good look inside ... then get a BIG piece of sheet-metal to close the top (IMG:style_emoticons/default/smile.gif) (IMG:http://www.sirandy.com/pix/914/07.30.2002/IMGP0266.jpg) |
Lo-Fi Version | Time is now: 20th April 2025 - 03:29 AM |
