red914 |
...i believe in coyotes and time as an abstract... ![]() ![]() ![]() Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 ![]() |
well, i have some ideas, but they are not good. it looks like it is coming out of the dipstick tube, or around the breather box (?) under the oil filler neck. it is not leaking a huge amount, just getting the top of the engine wet, with some oil pooling on the engine tin.
i have replaced the gasket between the engine and the breather box thing. that seemed to do it, but only for short drives. today went about 20 miles, and fresh oil was on top of the engine. it seems to be coming out laterally, and not really spraying all over; just flows around after it is down. any ideas? thanks ahead of time. |
red914 |
i thoght about the oil pressure sender and the dizzy o-ring, but the leak appears to be on the opposite, i.e. driver's side. the spray pattern points in the direction of the breather box, but the dipstick tube crack theory needs to be checked out. are those tubes press fittedinto the case, or threaded, or what? there is a blob of gray stuff on the tube, hardened; an old fix of some sort?
thanks for all the ideas. |
