Measuring tire temps at AX, What am I doing wrong? |
Joseph Mills |
Jun 15 2003, 08:49 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
At the last AX, after several runs, I went from 36# to 30# for the front tires (Hoosiers). At 32# and above, the inside was about 5 deg. hotter than the outside. Below 30# the outside started heating. At 30# they were about 117 deg. all the way across the tire. Good. And the car does not push.
The rear tires were about the same temps. However, even when I went as low as 26#, they are STILL about 6+ deg. hotter on the inside. And at 26# the car was starting to get a little loose, but easily controllable. Below are some things I've considered, but really, I don't know where to go from here. My car does have 1/2 deg more neg camber in the back than the front.... It was a short AX - around 38 sec's with some straight ahead driving - which would tend to heat the inside tread....? Maybe I need a faster/longer AX? Or can you only do proper readings on a skid pad or figure 8 only....? Could the engine heat up the inside of the tires? Usually spend 5 -10 minutes with engine idling and slowly creeping up the line.....??? My "pyrometer" is very cheap, but seems to be very reliable with repeated readings. Any ideas out there??? HELP! (IMG:style_emoticons/default/ph34r.gif) |
J P Stein |
Jun 20 2003, 02:12 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Don't ak me, I'm just trying to communicate/fit in. (IMG:style_emoticons/default/blink.gif)
Don't even know if it's C or F. I'm just glad I learned about this before I ordered the 200 degree springs. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:15 AM |
